Synbot Plugin icon Synbot Plugin — Synbot plugin for ARC: local Bot Server chatbot integration with SIML dialogs, ControlCommand API, multi-language, learning and emotion support. Try it →
Have you looked at the ARC manual? We have a short description on how to connect to your MIP. You can find it here.
i find that a little(ok a lot)hard to understand
SM, we can expand on the connection for you - however, it will not be until the new year due to limited available resources
Switzerland
Hi,
I have a MiP and I am currently using 4 x AAA 1.5 V Alkaline batteries. This provides 6 V to the MiP.
I am thinking of buying a MiP Recharge Kit(https://store.wowwee.com/mip-robot/mip-recharge-kit.html). I heard that the Kit consists of LiPos and that it would make MiP slower/less responsive. Is that true?
What is the voltage supplied by the Kit? Is it less than 6 V?
You do not power the mip off the ezb power source. Both will require their own power - although we recommend using a 9volt battery to power the ezb. You can see by the mip manual page on this website that the power is not shared - only the ground is shared because common ground is necessary.
Ps, do not duplicate post please. Your other post had been deleted.
