Custom Movement Panel V2 icon Custom Movement Panel V2 — Custom Movement V2 panel for ARC: scripts for F/R/L, Reverse, roll left/right, up/down with speed mapping to PWM for drones, mecanum & custom drives Try it →
Can't Seem To Connect Ezb 3 Up With More Than 9600 Baud
I have finished most all of my main ports in Sally.
But, it is running turtle slow. When it comes up and says connected, it is 9600 baud. I am running a W3 which has an I5 quad cpus and it should be faster than that.
I have almost ALL of the ports filled up. I am not even running any scripts, just checking each port to see if it works.
The graphix is slow to regenerate when you change windows.
I am sure that some of you have run into this before. I feel like if I could raise the baud rate it would be a tad faster. I had it set for 57K on the ports.
thanks!
It's ok, I found it. It is INSIDE of ARC (God Bless D.J.!)
I will run it.
If you have the ADC monitors installed like I asked and confirmed by you, than you will have to remove or pause them and follow Alan's advice to get your system back up to speed. I had this same problem when I first started with the V3 and the only way I could get my system back up to speed was to pause the monitoring. There's a little box to check right on the monitor window that will pause it. If you're still having problems please post your project so we can look it over and help.
I have seen this before. I stopped using the adc meters and only used adc charts and adc digital displays. Also I don't fiddle with the adc digital display multiplier, I leave it on the default. I can't say for certain that this was my fix, but I think it was. It was a while ago. Give it a try and good luck.
