Sound Servo (EZB) icon Sound Servo (EZB) — Map EZ-B audio volume to servos; multi-servo mirroring, scalar range control, invert/min-max, waveform feedback to sync mouth motion. Try it →
Cannot Connect To Camera
What EZ-Robot or product are you using?
Developer Kit
Is the battery on the robot fully charged?
Yes
Does the robot make a startup sound when powered on?
Yes
What color is the light on the EZ-B v4 and is it flashing or steady?
Flashing blue
Are you connecting the device to the WiFi network of the EZ-B v4 by following the video instructions on this page?
Yes
What error message is displayed in the status window at the bottom of ARC? Press the COPY button on the status window and paste the contents in the forum post.
Camera Initialized: EZB://192.168.1.1:24 @ 320x240 EZ-B v4 Camera Error: System.Exception: Client disconnected at EZ_B.EZBv4Video.zTXABOjcrh(Int32 , Object ) Camera Disabled
If an error appears, some devices take up to 1 minute to detect the ezb - wait 5-10 seconds and press connect again.
No luck.
If a connection still does not occur, are you certain your device is connected to the EZ-B v4 via Wi-Fi?
Yes
Have you double checked the wire connections to the EZ-B v4 using the very helpful learn section on our website?
Yes (No black wires on camera only white)
Reset the EZ-B and repeat this procedure if you are still experiencing issues.
Yes, several times
When resetting, does EZ-B speak introduction message as in the video?
Yes
If still unable to connect, inquire on the Community Forum and paste answers to these above questions. Also, provide what device is being used to connect to the EZ-Robot? (model/operating system) eg Windows 8/Samsung Note 3/Android, iPhone 6, etc
Windows 10 desktop with WIFI dongle and I have disabled my anti-virus software
Thanks for answering the questions - that helps a lot. I'm leaning toward a defective camera, which can be replaced using Contact Us. Can you verify the camera has lights on it? And do the lights cycle colors when the power is applied?
Yes, the lights to cycle when the power is applied but no lights are on after that. Update I get a flash of red light when it tries to connect.
Yeah - sounds like a defective camera. Use the Contact Us and we'll get you fixed up!
Great, thanks!
