Can't Connect With My EZ Robot
So I have an older Roli that we built six years ago and only just started working with before my laptop died. We dug Roli out tonight and I have a new laptop that I'm trying to link up with it, but it's not working out.
I've got ARC downloaded, and Roli fired up and his light is blue. But he's saying he cannot connect to my network, and when I look for him  on my WiFi, I don't see an option for EZ v4 on my WiFi connections options.
Ideas?
EZ-B v4/2 robot controller: dual Cortex ARM, Wi-Fi, audio/video, 24 servo/digital ports, I2C/UART, camera and Synthiam ARC control for custom robots
#1   — Edited
Reset your ezb. Last time you used it, it was connecting to your network. Just power on the robot and press the reset button with a toothpick or paper clip
i recommend visiting ezrobot website and following the tutorials to get started as a refresher. Plus, I star in some of the videos:D
Okay so I reset Roli, and he now shows up in my WiFi list, and I've selected him. Next issue: when I go to connect to him in my workspace, it won't connect and I get this message: EZB 0: EZB 1: EZB 2: EZB 3: EZB 4: Windows version: Microsoft Windows NT 10.0.17134.0 Missing 3D Bit: da4d8f53-a363-4371-b757-ad4c5219f553 Missing 3D Bit: 4141fcd0-0876-4186-a9b6-a1648706e6d0 Missing 3D Bit: b17e199c-a0b2-48c6-8037-ca56acab4be2 Missing 3D Bit: b17e199c-a0b2-48c6-8037-ca56acab4be2 Missing 3D Bit: 24875cdb-12d2-4145-8793-1e6afebf4f5b Missing 3D Bit: 4141fcd0-0876-4186-a9b6-a1648706e6d0 Missing 3D Bit: b17e199c-a0b2-48c6-8037-ca56acab4be2 Missing 3D Bit: b17e199c-a0b2-48c6-8037-ca56acab4be2 Missing 3D Bit: 24875cdb-12d2-4145-8793-1e6afebf4f5b Missing 3D Bit: b17e199c-a0b2-48c6-8037-ca56acab4be2 Missing 3D Bit: 4141fcd0-0876-4186-a9b6-a1648706e6d0 Missing 3D Bit: 2c0cf6f1-7dd2-48f1-84b3-6c2cc2960393 Missing 3D Bit: 418d3b5b-8ffa-4fb0-87c1-413246dbdcab Screen Resolution: 1366x768 (96x96 dpi) ARC Version: 2019.05.08.00 Attempting connection on 192.168.1.1:23 Connection Failed: System.TimeoutException: The operation has timed out. at EZ_B.EZB.Connect(String hostname, Int32 baudRate) Disconnected Attempting connection on 192.168.1.1:23 Comm Err: System.IO.IOException: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. ---> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- End of inner exception stack trace --- at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at EZ_B.EZB.mSZQFbMyx5(Int32 , Byte[] cmdData) BbytesToExpect: 1 U Received: 0 Disconnected Connection Failed: System.Exception: Controller Not Responding at EZ_B.EZB.IHHQ23cvDe() at EZ_B.EZB.Connect(String hostname, Int32 baudRate) Disconnected Attempting connection on 192.168.1.1:23 Comm Err: System.IO.IOException: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. ---> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- End of inner exception stack trace --- at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at EZ_B.EZB.mSZQFbMyx5(Int32 , Byte[] cmdData) BbytesToExpect: 1 U Received: 0 Disconnected Connection Failed: System.Exception: Controller Not Responding at EZ_B.EZB.IHHQ23cvDe() at EZ_B.EZB.Connect(String hostname, Int32 baudRate) Disconnected Attempting connection on 192.168.1.1:23 Comm Err: System.IO.IOException: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. ---> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- End of inner exception stack trace --- at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at EZ_B.EZB.mSZQFbMyx5(Int32 , Byte[] cmdData) BbytesToExpect: 1 U Received: 0 Disconnected Connection Failed: System.Exception: Controller Not Responding at EZ_B.EZB.IHHQ23cvDe() at EZ_B.EZB.Connect(String hostname, Int32 baudRate) Disconnected Attempting connection on 192.168.1.1:23 Comm Err: System.IO.IOException: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. ---> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- End of inner exception stack trace --- at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at EZ_B.EZB.mSZQFbMyx5(Int32 , Byte[] cmdData) BbytesToExpect: 1 U Received: 0 Disconnected Connection Failed: System.Exception: Controller Not Responding at EZ_B.EZB.IHHQ23cvDe() at EZ_B.EZB.Connect(String hostname, Int32 baudRate) Disconnected Attempting connection on 192.168.1.1:23 Comm Err: System.IO.IOException: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. ---> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- End of inner exception stack trace --- at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at EZ_B.EZB.mSZQFbMyx5(Int32 , Byte[] cmdData) BbytesToExpect: 1 U Received: 0 Disconnected Connection Failed: System.Exception: Controller Not Responding at EZ_B.EZB.IHHQ23cvDe() at EZ_B.EZB.Connect(String hostname, Int32 baudRate) Disconnected
#3   — Edited
Don’t dismiss the downloading of libraries that is prompted. Update to the latest ARC. And it appears there’s a firewall or virus scanner. When you receive the error about connecting, there’s a dialog which asks if you’d like to view the connection tutorial. Do that
windows is being more and more locked down these days - and with buggy unnecessary 3rd party virus scanners and firewalls, connection issues arise. You’ll find reference to that in the connection tutorial
Any problem I had connecting was always my anti-virus
Try disconnecting it
My 2 cents
I just changed my home network router and had to rediscover every one of my EZB's in my ARC project. I have 4. When I opened the connection window none of them would show up in the auto discovery window. Then I ran a search through the IP address window and all but one could be found that way. Then I dropped my Windows firewalls and all EZB's then could be auto discovered or manually searched for .
Seems like it is always the anti virus or firewall
