Pandorabots icon Pandorabots — Connects ARC to Pandorabots for AI chat, sends text and gets replies (executes [EZ-Script]), integrates with speech recognition and custom bots Try it →
C# Question About Invoking A Custom Action
Trying to call
EZBManager.MovementManager.GoCustom("Bow");
from a button click to invoke the canned Bow action.  Does nothing.  What am I missing?
JD Humanoid by EZ-Robot
Here you go - you have to bind to the movement event and retrieve the name of the custom action.
using System;
using System.Windows.Forms;
using ARC;
namespace Custom_Movement_Example {
  public partial class MainForm : ARC.UCForms.FormPluginMaster {
    readonly string MOVEMENT_JUMP_ID = "Jump";
    public MainForm() {
      InitializeComponent();
      // show a config button in the title bar. Set this to false if you do not have a config form.
      ConfigButton = true;
      // Bind to the movement event for every movement that is specified this will raise
      EZBManager.MovementManager.OnMovement2 += MovementManager_OnMovement2;
    private void MainForm_FormClosing(object sender, FormClosingEventArgs e) {
      // Unbind from the movement event when the form is going away
    private void MovementManager_OnMovement2(MovementManager.MovementDirectionEnum direction, byte speedLeft, byte speedRight) {
      if (direction == MovementManager.MovementDirectionEnum.Custom && EZBManager.MovementManager.GetCustomMovementId == MOVEMENT_JUMP_ID) {
        // Handle the code here for the custom movement type
    private void btnCustomMovement_Click(object sender, EventArgs e) {
      // This will execute the custom movement action
      EZBManager.MovementManager.GoCustom(MOVEMENT_JUMP_ID);
