Hi there.
Please could you tell me if i can use a simple on/off switch as a bumper switch on the ez-b tiny?? also can i use a Ir infrared obstacle avoidance sensor module?? Many thank charlie
EZB Stress Test
— Stress-tests EZ-B controllers (UART, ADC, voltage, temp, audio, digital I/O) to detect disconnects, corruption and stability issues.
Hi there.
you sure can, charlie. There are 8 digital ports on an IoTiny. Any of those can be used for a bumper switch. Because the power (+) pin of the digital port is battery, it can't connect directly to the bumper switch. Instead, use the red power pin (+) from any ADC port instead. That provides regulated 3.3v power. Wire that 3.3 v to teh bumper switch, and to the IoTiny digital pin.
And for the IR sensor, you can use any of the 2 ADC ports for that. There's controls in ARC for the IR sensor
including a cool radar scanner. Look here: https://synthiam.com/Products/Controls/Infrared-Distance
