@Athena which approach is recommended for a interactive robot which control by VR oculus. ARC on Pi as a brain to robot, 4 motors and serial servos as arms to Arduino mega here i have another doubt also Hbridge skill has only 2 motor control. if i have 4 motors how to control it.
kslaxme
India
3 Participants
Building A VR Controlled Robot
Unnamed Plugin
by Ellis
Dual Hbridge W/PWM
by Synthiam
Dual H-Bridge w/PWM movement panel: control two DC motors' direction and speed via EZ-B PWM for responsive forward/reverse/turning.
@Athena , How to make the robot to feed basic information about the robot Say about yourself, What do you do? , How long will you run? these are all conversational questions asked to robot? how to preload answers to the robot, give me sample script to load the answers to the robot to speak.
To preload answers for your robot to respond to conversational questions,you can use ARCs scripting capabilities to create a script that listens for specific phrases and responds accordingly.Heres a step-by-step guide and a sample script to get you started:
Step-by-Step Guide:
Add Speech Recognition Skill:
Configure Speech Recognition:
Create a Script for Each Phrase:
Audio.say()orAudio.sayEZB()function to make the robot speak the response.Assign Scripts to Phrases:
Sample Script:
Here's a sample script for the questions you mentioned:
Assigning Scripts:
aboutYourself()script.whatDoYouDo()script.howLongWillYouRun()script.Testing:
By following these steps, you can preload answers to common conversational questions and enhance your robot's interactivity. If you have any further questions or need additional assistance, feel free to ask!
Given your goal of creating an AI-powered robot, I'd use one of the several AI robot skills available. Specifically, I'd use the Open AI GPT robot skill, but you can choose the one you think is best. Find them here: https://synthiam.com/Support/Skills/Skills-Overview#Artificial-Intelligence
Please do not comment about unrelated topics any further on other threads. Keep your conversation about the robot that you are building in this thread. It helps us organize the forum for others who learn from reading manuals and watching others receive assistance.
, I plan to use a Raspberry Pi 5 in my robot, with Windows 11 installed and ARC running on it. The information provided on the website regarding the setup of single-board computers (SBC) seems outdated and unclear. Could you please provide more detailed and up-to-date instructions on how to configure a headless setup for the Raspberry Pi to automatically run ARC from startup?
The getting started guide will be of use to you.
By scrolling up, as mentioned in point #4, you'll see all the answers given to you. If you spend an hour focusing on the answers, you will have the robot running.
I beleive you are distracting yourself with too many goals and not focusing on a single task. Start by splitting your goal into smaller micro-goals. Tackle each micro-goal in order.
Incase you are not able to find your account profile to see past posts you have created, the link is here: https://synthiam.com/User/Profile/kslaxme
Follow that link to see the multiple topics you have created and the answers that have been given.
@Athena , how to feed the x,y,z values from other skills like oculus quest robot for example right controller value to inverse kinematics skill to control servos.
To feed the X, Y, Z values from other skills, such as the Oculus Quest robot skill, to the Inverse Kinematics skill in ARC, you can use the
ControlCommand()function to pass the coordinates. Here's a step-by-step guide on how to achieve this:Identify the Source of X, Y, Z Values:
Access the Values:
getVar()function to access the global variables that store the X, Y, Z values from the Oculus Quest robot skill. For example:Send Values to Inverse Kinematics:
ControlCommand()function to send these values to the Inverse Kinematics skill. ReplaceInverseKinematicsArmwith the actual name of your Inverse Kinematics skill in ARC:Integrate into a Script:
Test and Adjust:
By following these steps, you can effectively control the servos of your robot arm using the X, Y, Z values from the Oculus Quest right controller or any other compatible input device. If you encounter any issues or need further assistance, feel free to ask!
seems like it doesnt has any relavant global variables representing left and right controller position, how can define the data as a variable and use in script?
