XV Lidar Bridge icon XV Lidar Bridge — Neato XV LIDAR integration for ARC with live radar, 8-zone obstacle detection, NMS support, calibration, and scan watchdog monitoring Try it →
Brookstone Rover
Brookstone Rover
Hi DJ,
I have just purchased the Brookstone rover + the Ez Robot complete kit.
I am very skilled in IT / programming and cannot get the rover to connect to the Ez Builder software.
The PC is connected to the Rover via Wifi and I can access the IP of the units DHCP and login using the AC13 credentials.
I cannot however get the software to connect, it simply refuses to do so.
I am not certain if I have a 2.0 version of the rover, is there anything else I should be checking?
My rover is a dark green color model: GT-3598
Cheers
Today's release includes brookstone rover connection debug information
Hi DJ,
New debug output from the new version is below:
If really needed, I can try to get tcpdump running on an iPad. I work in a very resourceful IT company and we have been driving the rovers around the office;)
Rover Connection Error Step 6: System.IO.IOException: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. ---> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- End of inner exception stack trace --- at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at System.IO.Stream.ReadByte() at EZ_B.BrookstoneRover.Connect() Rover Connection Error Step 7: System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection. Parameter name: index at System.ThrowHelper.ThrowArgumentOutOfRangeException() at EZ_B.BrookstoneRover.Connect() Rover Connection Error Step 8: System.InvalidOperationException: The operation is not allowed on non-connected sockets. at System.Net.Sockets.TcpClient.GetStream() at EZ_B.BrookstoneRover.Connect() Rover Connection Error Step 9: System.InvalidOperationException: The operation is not allowed on non-connected sockets. at System.Net.Sockets.TcpClient.GetStream() at EZ_B.BrookstoneRover.Connect()
Where did you buy this tank? I can't find any information about it.
Also here are some pictures after it has been ripped apart:)
Ill be fitting a massive Gel Cell battery (6amp) in the back there.
A couple of top platforms (one will hold the motherboard from an atom Eee PC)
And then on top I will have a swivel second camera.
I will also be adding a Z-wave home automation controller on-board so that it can act as a portable room open air mic for turning appliances on and off.
Some decent speakers too if they will fit:D
I am looking to get 1 week battery life running 24/7 ideally.
Might need to upgrade the engines though, I will see how it goes.
#15
Supporting that device is added to our to-do list. I do not have an eta, but there are over 100 items ahead of it
#16
Hey guys, i'm trying to connect my rover to the ARC, but it won't connect. A mesage scrolls up from the bottom saying:
Rover Error: System.IO.IOException: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. ---> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- End of inner exception stack trace --- at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at System.IO.Stream.ReadByte() at EZ_B.BrookstoneRover.Connect()
What does this mean? What should I do?
