Camera Snapshot icon Camera Snapshot — Save camera snapshots to 'My Robot Pictures' (Pictures folder), manual or timed (0-100s), and trigger programmatically via controlCommand. Try it →
Ireland
Thanks Rich Just noticed the one I queried is bluetooth ver 2 as I use ver 1 dongle on one pc best to stay with that
Just to throw all the details out there, since I have the mdule off the board at the moment.
It's a JY-MCU BT_Board V1.05 4 pin bluetooth ttl module
Thanks for the mention Rich. The Class 1 Bluetooth that has 6 pins of which the center 4 will mate up with the EZB(V3) can be ordered from Sparkfun.com Here is the URL Link
You will also need to order a male header strip so that you can solder it to the 4 center pin connections. Then you can plug it directly into your EZB(V3)
Ireland
Thanks Robot-doc & Rich Would like to use class 1 Bluetooth but in this case it will have to be the cheaper option Pat
