Camera Overlay icon Camera Overlay — Displays trained object names as overlays on the Camera Device video stream using Camera Device's object-tracking (shows $CameraObjectName). Try it →
Could you please send me sample images or vedio to check the charging of the battary to ensure that i am testing with the valid scenarios because i am sure that the battery charging level is not 0 as the green led is off in the second time charging. I think the main issue is how to check the output of the battary device
Hi;
In the back of the JD body, there is a power plug that has two connectors that you plug the EZ-B v4 into them. You have to check the voltage between these two connectors, it has to be about 7.4 - 8 V DC. To do this follow these steps:
1-Charge the battery
2- with the EZ-B v4 not plugged in, turn the switch on.
3- Measure the voltage between these two connectors. BE careful that each test probe of the voltmeter is only touching one connector and they are not touching each other (Do not short circuit the two connector together).
4- If the voltage is zero, this means that the 20 A fuse inside the body is blown out and has to be changed.
May be you need to open the body of the robot. There is four screws that you need to unscrew. Inside the body there is a 20A fuse. This fuse may be broken and has to be replaced.
When you open the body try to memorize how the parts inside it are arranged inside it, this will help you when you reassemble the body.
