Feetech RS485 Servo icon Feetech RS485 Servo — Control Feetech serial bus smart servos via EZB UART or PC COM port in ARC using virtual ports mapped to servo IDs. Try it →
Resolved Resolved by ptp!
Battery Charging Incorrectly
I attempted to charge my robot's standard 2 cell 7.49 volt battery, but I received the error of "300 MV difference between charger and battery." I was using the standard included battery charger. I visited the forums to investigate this problem and was told that disconnecting the battery from the robot would help it charge, instead, I received the Error, "The battery connects incorrectly." I don't know if there is something up with the charger, or if it's the battery having been drained to low. to anyone who replies to this post to help me through this problem, you have my thanks.
Thanks for the solution ptp, I have both of these and I thought I could use a multi meter to charge the battery above 300 MV. Unfortunately, i do not have either with me right now, I will regain access to them soon.
