Aimlbot icon Aimlbot — Localized AIML chatbot with editable AIML files, ez-script support, session memory and ControlCommand API; integrates with speech and robot skills. Try it →
Attaching Ez-b & Servos To Wild Thumper
Attaching Ez-B & Servos To Wild Thumper
I am working on my first project involving Wild Thumper, and need to figure out how to attach the different pieces (EZ-B, servos, camera, distance sensor, etc.) to the Wild Thumper chassis. The EZ-Robot Complete Kit came with several screws and other things that look like they are intended for attaching different components to stuff, but I did not come with anything that says what is for what. Also, the Wild Thumper chassis has a grid of holes for attaching things, but without something to put on the other end of the screws that came with the EZ-Robot Complete Kit, that doesn't help much. Are there any good videos on how to attach stuff to the Wild Thumper chassis? Thanks.
Try a nut and bolt, wire tie, hot glue, sticky tape, bubble gum, plaster-cine, band-aide, melted ice cream, duct tape, any thing that will hold it to your satisfaction, what ever works use it there is no single way to fasten everything on.
For some parts, I probably will use some of those techniques, but I would still like to know what all the screws and things included with the Complete Kit and Wild Thumper are for. If something was designed for a specific purpose/task and that task is one you need to accomplish, it is usually most efficient to use it for that task.
i looking at using aluminium mounting,easy to remove if a problem happens,light weight and and a lot stronger the hot-melt glue
