Ohmnilabs Standalone icon Ohmnilabs Standalone — Connects Ohmnilabs Telepresence robot's UP Board COM to ARC, enabling drive and servo control (neck V0) and integration with ARC cameras. Try it →
Ar-Drone V.1 Navdata
Hi, i am trying to get the navdata out of the AR drone while tracking an object. i was able to retrieve th object position using the following script
$filenamex = "c:\logx.txt" %create log for x coordinates% $filenamey = "c:\logy.txt" %create log for y coordinates% :START
%retreive centroide position%
IF ($CameraIsTracking = true) $linex = "$CameraCenterX" $liney = "$CameraCenterY"
%write in the assigned files% fileWriteLine($filenamex, $linex) fileWriteLine($filenamey, $liney) ENDIF sleep(100) GOTO(START)
could you please assist me: how can i retrieve navdata of the gyro, accelerometer and sonar (altitude) while tracking to a log file similarly to the above? i am planning to calculate the positioning by using the following formula S= S0T+vT +0.5aT2? hence S will be equal S= 0.5aT2..... i can't find (a- acceleration) without the accelerometer (i am transforming g-force acceleration to m/s^2)....
My aim is to compare the movement of the object with the movement of the drone..
sorry for the long story... best regards ... ([email protected])
I don't understand the scripting language that you've posted. All of the NAV Data is available as variables when a AR Drone Movement Panel has been added.
  1. Load ARC
  2. Project -> Add Controls -> Robots -> AR Drone Movement Panel
  3. Project -> Add Controls -> Scripting -> Variable Watcher
  4. Connect to your AR Drone using the instructions (press the ? question mark button on the AR Drone Movement Panel for a video tutorial)
All of the nav data is available in Variables once the AR drone Movement Panel has been used
