Irobot Roomba Movement Panel icon Irobot Roomba Movement Panel — Control Roomba/Create via ARC: drive, stream sensors, read encoders, configure COM/HW UART, and send pose to NMS for mapping/navigation. Try it →
Possibly fixed now with the latest version Here
Ireland
@winstn60 Thanks for reply Downloaded latest version , but no success
the "wait" command works ok ?
Pat
latest update Works but is not reading values properly
confused
I've tested this and it works. What are you experiencing?
Ireland
at present my script reads
if (adc(adc0) > 10 ) servo(d1,29)
voltage 5v on adc0 graph
but servo does not register in debug
same in <
getadc(adc0)
reads value ok
The documentation is incorrect. It is GetADC(adc0)
Ireland
Thanks Dj
Sorry I may not be explaining it clearly
This is the script I entered
GetADC(adco) If (ADC(ADC0) > 5) Servo(d1, 29)
when I run this is the debug reply
Start GetADC(adc0) 134 If (ADC(ADC0) > 1) Done
as you can see adc value is 134 , Get command responds ok but " If " Statement does not
script two example
GetADC(adc) If (ADC(ADCO) < 1) servo(d1,29)
When I run this is the debug repy
Start GetADC(adco) 134 If (ADC(ADC0) < 1) servo(d1,29) Done
Get, responds with correct value , but " iF " statememt even though its not true , it moves the servo
Hope I have outlined it a little clearer
pat
Again, the script manual was incorrect for the IF condition. The syntax is
if (GetADC(adc0) < 1)
  print("It is less than one")
Get the latest ARC and notice the manual has been updated. The manual was incorrect. The proper command is GetADC().
Ireland
Thank you Dj Dowloaded update and entered new commands all works very well. excellent
Take the remainder of the day off !
Ez-b is no 1
nothing comes near.
Pat
