Recorder icon Recorder — Record and replay EZB communications (servo & digital commands) with forward/reverse playback, save recordings and trigger them from scripts Try it →
Ecuador
Question With Examples In Sdk.. Help?
HI! everyone..
I have been using Visual C# and I can not do to work the examples... in every example of the SDK I have this problem...
If someone can help me?
I am Using Windows 7 x64 4GB ram Amd Phenom x4
I bet you haven't followed the instructions in the readme.txt file:)
Ecuador
OOHh!!! haha sorry Dj.... I am starting.... hahah I am a noob jajaj!
Hehehe that's okay:) that question gets asked a lot by sdk users.:)
Readme files are usually pretty uninteresting. That one is important!
Ecuador
haha:) yeah.. we are learning... mmm only one favor more.. can you give one example to use pwm for example in port D1 I want to send 5v...??? (now i am making the contro of hbridge with pwm...) because only this part.. i can not understand... thanks!
If you want +5 then you don't want PWM. PWM allows you to vary the voltage. For example, if you wanted +2.5 volts, than you would use PWM.
For +5, you can use the Digital functions.. Here's an example..
      // Turn D0 on (+5)
      ezB_Connect1.EZB.Digital.SetDigitalPort(EZ_B.Digital.DigitalPortEnum.D0, true);
or
      // Turn D0 off (+5)
      ezB_Connect1.EZB.Digital.SetDigitalPort(EZ_B.Digital.DigitalPortEnum.D0, false);
and for PWM on D0 you can use this
      // Set PWM for D0 to be 50% (2.5 volts)
      ezB_Connect1.EZB.PWM.SetPWM(EZ_B.Digital.DigitalPortEnum.D0, 50);
Ecuador
is working!! thanks!...:)
I have a lot of things to do with sdk!:)
