Irobot Roomba Legacy icon Irobot Roomba Legacy — Legacy iRobot Discovery and 4xxx control via EZB software-serial (D0), supports Arduino/EZ-Robot, adjustable baud rate; not for hardware UART/USB Try it →
Set Timing On Digital Ports
Hi Guys,
Having a good time working on my LED Array project. Thanks for all the help so far.
I was wondering if its possible to set the time a digital port stays 'true' before returning to 'false'. E.g. ' true' for 0.5 of a second before reverting to 'false'.
I noticed that in ARC there is control you can add to set the read time of a digital port. Is there any code in the C# SDK that can do the same thing, or any other method using C#?
Thanks
danUK
The time you are referring to is a min request time. It prevents too many requests from flooding the communication channel. Think of it as a safety net.
What you'd like to do is use a timer, or timers to hold the values for a specified time. That would be up to your program.
