EZB Connection icon EZB Connection — Connects EZ-B I/O controllers to ARC via COM or IP (5 connections). Supports init scripts, battery monitoring, TCP/EZ-Script server and serial/I2C. Try it →
Hello,
I just started with a login and willing to download tonight to start building robots. I am very beginner but I have a question about the hardware.
Do I have to buy the body part (except electronics) or I can I just 3D print it them?
on your website I could only download a portion of each piece https://www.ez-robot.com/Community/Revolution/EZBitDetails.aspx?guid=4141fcd0-0876-4186-a9b6-a1648706e6d0
Hello , you can print all of the Robot body parts except Roli body because there are gears in that body that are too small to 3d print. If you want to print a six or JD Robot then you can print everything you need !
