Revisiting Power Supplies
Hey guys, I'm trying to use a single power supply AC to DC 12 volt 20 amps and I want some kinda step down converter to 7.4 volts.
To be clear I have half a project running at 12v and the other half at 7.4 volts. I'd rather not have two power supplies if i can help it. Any suggestions on best way to step down?
Also do the amps stay the same if you step down. This will be a Mean Well power supplies.
Thanks for any feed back.
Edit: or a dual voltage power source 12v and 7.5 sharing 20 amps
I've found some Dual voltage power supplies but the second voltage is listed as -12 volts. What does the minus mean in voltage terms?
Dual voltage
You do lose amps when you step down. Some much more than others.
I have been looking at this adjustable high amp BEC for a similar purpose. https://www.amazon.com/dp/B000MXAR12 I haven't ordered it yet. Note: it requires a USB programmer to adjust the voltage: https://www.amazon.com/Castle-Creations-Link-Programming-Adapter/dp/B000BOG8V0
I have also looked at this one https://www.amazon.com/dp/B00RSOOBYC but the Castle Creations one was recommended by @Dave Schulpius so I am leaning in that direction since if there is one thing he knows, it is electric power... https://synthiam.com/Community/Questions/7537&page=2
