On An Arduino You Can Use Anal
On an Arduino you can use Analog pins as digital pins (ie on an Arduino Nano pins D0-D13 are digital pins, A0-A5 can be used digital as pins D14-D19) Is this also possible with the EZ-IOTiny?
No - the pins of the iotiny are what they are. You can use an Ez-b V4 for more adc. Or, use the communication protocol data sheet and connect an arduino to ARC.
Thanks for you quick response. I also have a Ez-b4 but that would not fit inside. Currently working on a UART connection with an Arduino Nano to offload some work. That's how I found out that you can use Analog pins as Digital ones, hence the question ;-)
