Dual-Axis Compass icon Dual-Axis Compass — Dual-axis I2C magnetic sensor for EZ-B robots enabling magnetic direction sensing; requires short 2-3 in wiring. Third-party hardware. Try it →
Script To Select Camera
Hi,
Something is terribly annoying : ARC resets its default camera so if you are using a different camera than the ezb camera, any script that is supposed to boot your cam and then start it in the camera settings will not activate the one you want.
Is there a way to select a camera in the list as default and lock it so it stops bugging me like trying to force me to buy the low res ezb camera ?
thank you.
PS : ezb v4 is full of bugs. I can't count how many I meet. It is VERY unstable. Please, provide us with a firmware at some point. It is really very annoying. few examples :
-ezb disconnects -ezb has flawed digital ports : servos and motors won't respond ezb needs to be disconnected then connected again -ezb v4 used in conjunction with ezb V3 will screw all servos mixing up the old 100 position values and the new 180 positions. ARC has a very slow response rate - often due to a wifi board that is too slow, apparently, or a flawed buffer in the software, Idk. -digital ports will all lock to ON position and turn the robot totally nut and crazy -ARC will crash, very often, as soon as more than 3 scripts run at once. -i2C port is far too unstable. and so on... can't remember all the bugs I've encountered but it is really a lot.
#41
@Dj
Ok, now I see a little bit more clearly in this.
I just did a test : If I run the camera (using alax.info driver) using the command :
 ControlCommand("Camera", CameraStart, "Rover")
I get the same error message as before, the one that you said was hardware related.
But if I manually select the camera in the list and run press the start button or run the following command :
 ControlCommand("Camera", CameraStart)
that is to say, without specifying the driver or any item whatsoever, then it works.
Any idea on what can make that happen ? Can it still be just hardware related ?
Thanks.
