MPU6050 Accelerometer Gyro Temperature icon MPU6050 Accelerometer Gyro Temperature Reads MPU6050 gyro, accelerometer and temperature via I2C, initializes and returns data on-demand to EZ-Script variables using ControlCommand RunOnce Try it →
Gibraltar
Need V8.5 ARC
i think i need an earlyer version of ez build coz i can't connect to v15 plus keep gettingerr msg on ez update Attempting connection to COM3 EZ-B reports EZ-B Firmware V8.5 Connected Usending ping Usending ping Usending bootloader Failed to load bootloader! any advise thanks
there is no version 8.5.. you are connecting to your computer's internal modem. You'll need to follow the tutorial on the website on how to add the EZ-B to your computer. the tutorials can be found by clicking on the menu item labelled "Tutorials"
Gibraltar
sorry to be a pain got rid of software that came with bt dongle useing Microsofts now still getting err msg Attempting connection to COM6 Connection Failed: System.TimeoutException: The write timed out. at System.IO.Ports.SerialStream.Write(Byte[] array, Int32 offset, Int32 count, Int32 timeout) at System.IO.Ports.SerialPort.Write(Byte[] buffer, Int32 offset, Int32 count) at EZ_B.EZB.Connect(String portName) Disconnected any idea watched tutes following it but sill having probs what am i doing wrong stress
you've received two COM ports when adding? I suspect COM6 and COM7?
You can try the other COM port, but it's supposed to be the lowest - although i've heard a rumour that someone had it reversed and it worked... technically that's improbable, but i've seen stranger things in windows
When you attempt a connection, what do the LED's on the EZ-B do?
Gibraltar
got two com ports COM4 & COM6 the blue LED just keeps flashing the bt LED stays on for few seconds then flashes as before the best i had is bt LED slowly flashing got this msg on ez-b firmware updater Attempting connection to COM4 Comm Err: The operation has timed out. BbytesToExpect: 1
Received: Disconnected Connection Failed: System.Exception: Controller Not Responding at EZ_B.EZB.Connect(String portName) Disconnected
Netherlands
Twitter YouTube
The EZ-B LED is supposed to be slowly fading while the BT LED is flashing.
When it's connected, they both just remain solid.
I think it's a problem with your bluetooth COM-port..
Gibraltar
and......... sorry don't mean to be rude just getting frustrated, so how do i fix it
When you power the EZ-B, you have red and blue flash?
When you press the CONNECT button in ARC for COM4, does the RED led stop flashing for a second? And the blue continues to flash?
Gibraltar
YES exactly what happens i know i'm being thick sorry. but it was a prezzy from my wife and don't want her to be dissapointed thanks
