Set Digital icon Set Digital — Toggle a digital I/O port between TTL low (0V) and high (3.3V/5V) in ARC; select board and port, simple on/off control-signal only. Try it →
Ukraine
Twitter
Native C Or C++ Api (Without .Net)
Hi guys, hi DJ,
Is there any possibility to program EZ-B without dependency on .NET Framework? Unfortunately .NET is quite unportable (even with Mono). I'd like to control robot using Android or Linux application for example.
I guess I don't need a full SDK with such functionality like picture recognition or support of twitter and RSS. I just need to control the exact device somehow (servos, sensors etc.). If you don't have a C library for this it would be great if you at least open the source of corresponding part of .NET implementation. Or maybe you have some reference. Basically I need to know which data and where should I sent in order to control the EZ-B module.
Thanks in advance.
-- Sergii
Ukraine
Twitter
Thank you! I'll take a look on it. Seems to be usable.
-- Sergii
