Joystick (Direct Input) icon Joystick (Direct Input) — DirectInput joystick control for ARC: drive movement panels, control servos, assign button scripts, variable speed and rumble feedback. Try it →
Mouse Wheel Control
DJ, You know how you can click on an area on the screen and you then can scroll up or down with your mouse. This works on all the controlls in ARC however if you click on the background it does not work. It would be really slick if it did with the size I am working with. Right now it takes up about two screens worth and I have to use the scroll bars. Just a thought if it is something easy for you to fix.
