Sabertooth Movement Panel icon Sabertooth Movement Panel — Sabertooth movement panel: control two motors via Simplified Serial with variable speed sliders, movement buttons, and serial port options. Try it →
What version of windows are you using? Windows 8+ should already have the required .NET framework. Windows 7 you may need to update your .NET. Below Windows 7 is not supported.
(no image of the error was attached to your post).
Ok, thanks. I'm on Windows 7.
