Joystick (Direct Input) icon Joystick (Direct Input) — DirectInput joystick control for ARC: drive movement panels, control servos, assign button scripts, variable speed and rumble feedback. Try it →
How Do I Set Up Ez-b V4 To Use An Rc Esc With Linear Actuator?
How Do I Set Up Ez-B V4 To Use An Rc Esc With Linear Actuator?
Hello All,
Anyone know how to wire/configure to use an RC ESC with linear actuator to be controlled by the EZ-B V4 and ARC?
Does it get wired/configured the same way as an H Bridge?
Also, if it is possible to do, how many ESC's can I use with one EZ-B V4?
The robot I am building will need 7 ESC's with linear actuators and one Sabertooth 2X32. I have no problem controlling the ESC/actuator with a Radio control PWM signal, so it seems it should be possible with the EZ-B V4.
Look at string potentiometers for feedback. Relativity cheap and easy to buy or make, and mount. There are 3d plans for making them.
Yeah, I've seen that article before and would like to try it but dont have a 3D printer yet. I am going to get one, but need to know the minimum size required to print the INMOOV android. I have also been looking at linear potemtiometers, which come in different sizes.
