Inverse Kinematic Arm icon Inverse Kinematic Arm — Control robot arms with inverse and forward kinematics, converting X/Y/Z positions into joint motion and reporting end-effector location. Try it →
Try removing the EZ-B from the list of connected devices under your bluetooth management, power off your EZ-B. Replug power in and re-pair the EZ-B look at the com ports added and use the lower com as I am sure you know then try reconnecting.
