HMC5883 Compass icon HMC5883 Compass — Reads HMC5883 3-axis compass via I2C and updates EZ-Script variables on demand; polled control offers periodic heading data, for connected sensors. Try it →
Brazil
Help! My Ez-b Does Not Respond To Any Command!
Help! My Ez-B Does Not Respond To Any Command!
DJ! (and Friends!), please I need your help. I had an accident with my V3 (my little son STEP (!) on it while I was installing at the base of a robot!).. so, as a result, it broke two legs of the Power regulator (LM1084). So, I carefuly removed it, and soldered it back. Well, the board Lit up, connected to ARC... BUT it flows NO power to the servos, (D0 to D19 receive no power at all!)
Do you think something else could have brake ? like some circuit path or something ?! I examined and could not find any other damage... and the voltage is getting correctly to the power regulators....
ANY HEEEELLLP!?!
thanks...
Well, it's not really a solution, just a road map. You will have to do the work and thinking. Good luck! ;)
One other thing to check would be the fuse. You can use the continuity test to check that the fuse is good.
