ADC Meter icon ADC Meter — ADC VU meter displaying 0-3.3/5V as a 0-255 linear meter; configurable board/port, sampling interval and color; pausable real-time readings. Try it →
Getting Ther, But I Need Some Expert Assistance
Hi there ezroboter's!
I'e been a lurker for quite awhile and fairly recently got my developer's kit. I'm having blast so far! I posted some months ago to inquire of the ez-b v4 board would support my Kobuki base which i received as part of a Turtlebot 2. It's a supercharged iRoomba/create (no vacuum parts, but quite a bit more power, lots of connections. Bigger battery, etc.).
Folks assistance in those early days is much appreciated as it allowed me to move forward, but I appear to continue to hit a wall. The Kobuki base is reportedly electrically compatible to the iCreate, however, I can't get the ice-robot Roomba project to connect.
If you look at the user's manual on page 10, you'll see the wiring diagram for the db25 serial port (linked below). The major difference between the iCreate and the Kobuki is that there's no ps/2 connector like the one is the video tutorial. I've got a servo (3 wire) plugged into D0 of my ez-b and disconnected the power wire. I've got ground going to pin 25 and the signal wire going to the pin 1(serial rx) on the kobuki. I have a suspicion that I should have my signal wire going to to the Kobuki's D10 which is its pin 3.
I figured I'd solicit the community's advice before moving forward. I have managed to get two arm's constructed from A12's Dynamixel's and a few other items integrated but this one worries me simply due to the cost of the Kobuki:)
https://gilbo.com.tr/kobuki/files/Kobuki-UserGuide.pdf" target='_blank' rel="nofollow">Kobuki Userguide
I'm not going to mark as resolved yet, but there are multiple approaches. I'll look into them this weekend and report back!
Thanks for everyones time and ideas!
Happy Saturday!
I finally got my replacement Kobuki base, turns out the first one was defective. I've tried both of the above approaches with differing results... Neither proved absolutely successful but I am making progress.
The UART solution just didn't work. Im fairly certain I could get it to work with enough time.
I also tried connecting D0's signal pin to AI0 and D1's signal to AI1. I didn't connect either of the digital ports power or ground and instead connected another pins ground to the rs232's ground pin. I confirmed voltages from 0.0 to 3.3 on the signal wires. So this is really promising. To be clear, I only have D0 and D1's signal wire attached and a ground connection attached to the platforms RS232 port. Nothing else.
The bummer is that when I enable the motors by pressing B0 button, both wheels just spin regardless of the PWM slider. I do here the wheels reacting to movement of the PWM slider but it almost feels like its affecting torque and not speed, or something.
I couldn't find any place to set the baud rate within ARC but on page 11 of the linked doc above it notes the following are required..
Baudrate: 115200 BPS Electronic protocol: USB / RS232 (@ DB25 connector)
I feel like I'm missing something obvious:) Are there different types of PWM outside of the digital pins signal being increased or decreased? Do I have to connect the tx and/or rx pins to the RS232?
One new key finding.. The voltage for pwm is a signed int 0.0 to 3.3 volts. Negative volts causes motors to run in reverse.
Such a frustrating day... On the Kobuki mailing list they are stating I am likely not connecting ground to a common ground between the EZB and the Kobuki base...
I've reduced the problem to only attempting to control a single wheel. EZB v4's D2 signal wire to AI1 and D2's ground to D25. I'm measuring 1.65V which is reportedly the exact voltage needed to get the wheels to stop spinning...
No luck still. They claim the UART/Serial interface is much better, but I haven't been able to decipher the protocol enough to create a working example.
