BV4615 RC-5 IR Decoder icon BV4615 RC-5 IR Decoder — Adds IR sensor support and button mapping for USB joysticks in ARC, enabling remote control functions; third-party hardware supported. Try it →
Controlling A Robot With Android Wear Smartwatch
As discussed in this thread: https://synthiam.com/Community/Questions/9107 I have been working on controlling my robots from my new Android Wear watch.
Eventually, I want to make a plugin and an Android Wear app to make this easier, but with the combination of 3 (unfortunately, all paid) android apps, I now have a controller. Note: Unlike the Apple watch app that DJ wrote that uses ARC Mobile, this one requires a PC running ARC and the TCP Client connection activated.
The app has 5 configurable buttons, which I have set up for basic movement panel, but each button actually supports tap, double tap, press and hold, and swipe so I could add 15 additional functions.
It uses the following three apps:
Tasker https://play.google.com/store/apps/details?id=net.dinglisch.android.taskerm
Send/Expect https://play.google.com/store/apps/details?id=com.asif.plugin.sendexpect
and AutoWear https://play.google.com/store/apps/details?id=com.joaomgcd.autowear
There are some issues with AutoWear on Android Wear 6.0.1 (the latest version) but none that impact this function, it just took some work to set up because I could not get through the setup wizard, and some of the features (like gesture support) don't work, but the multi-button function I used work fine.
If anyone else has an Android Wear watch and wants me to put together a tutorial, post here and if there is enough interest I'll write up instructions and post my Tasker files.
#25
Quote:
if you download the Google rewards app you'll soon accumulate enough credit to pay for the apps
Good point. I bought Tasker years ago because it is so valuable in its ability to extend Android and automate things I used to do manually, but I bought both of the add-ons with Google Rewards credits.
Twitter Google+
#26
I really only buy things now with the Google rewards. It can be quite easy to manipulate. I figured out the (semi) local stores that always send a survey if you visit and make a point to walk past them even if I don't call in. Guarantee a survey 24/48 hours later :-)
#27
If you add any interesting capabilities to this idea please share. The one I plan on doing is having multiple faces available for different robot functions (launching each new face with a swipe on the currently open face, although our discussion of integrating AutoVoice into the mix has me thinking of some new ideas too.
Twitter Google+
#28
I will do. I was thinking also of autovoice integration.
I'll let you know if I get there.
Paul.
#29
I haven't modified the code yet, but I have been playing with the ARC HTTP Server (custom) control and realized that I can send script commands using HTTP Get and don't need the Send/Expect telnet client.
Format is:
get  https://host:port/script.cmd?code=script statement
(note: this is not documented, so could potentially change with ARC updates. I discovered it by capturing packets when using the HTTP Server (custom) web page and watching what happened when I hit the buttons)
