Can'T Download Andriod App
Hi, I'm a newbie...
I'm having trouble downloading the Android version of ARC from the EZ Robot website. I'm getting a message on my tablet that says "For security, your tablet is set to block installation of apps obtained from unknown sources."
There's a "Settings" button just below the message which I would assume leads you to where you can over ride this problem, but I don't see where.
Am I missing something?
You can change that in your android settings. Do this in your settings on your device.... This will allow you to download the app
You might also be able to download it from google play... Not sure as I haven't check to see if it is there...
it is not in Google play yet.
On your android device, go to Settings, then Security, then find the "unknown sources" item and check the box next to it. You'll then be able to install the ARC for Android app.
Thanks - I just found the setting to change. BTW - I didn't see it on Play. I tried that too. Thanks -
Tom
