Task Script icon Task Script — Split complex robot tasks into sequential scripts, synchronizing asynchronous skills via NEXT/CANCEL commands for staged automation. Try it →
Ireland
Bluetooth Bandwidth ?
I am using a bluetooth dongle to connect Ez-b and connect PS3 control ,no problem works very well, excellent
Purchased a bluetoot headset for voice command of Ez-b.
when I open my ez-b file before making connection (to ez-b ) voice commands appear in window ,but once I connect to Ez-b I loose voice command I presume its my bluetooth ability to operate the connection and headset.
Any suggestions would be appreciated tried setting up a second bluetooth device no success is there some software that would allow this ( windows 7 )
Pat
Hi Pat,
Its not a Bluetooth problem you have but probably a clash of com ports or a lack of ports see if you can identify via Windows devices and printers panel what com ports are in use
Bluetooth is a frequency hoping system changing channels within a range of frequencies at something like 800 times a second. That way many devices can share a limited bandwidth.
Try deleting the EZ-B Bluetooth connection pair your headset then pair the EZ-B again
Interested you have your PS3 controller working with Bluetooth do you use the Motionjoy driver?
Ireland
Thanks for reply Thats also what I thought but after much experimenting with two different dongles it does recognise both devices ez-b and headset and will connect to both but not at the same time. Tried all settings to try and limit headset features eg using mic only but no success. I installed a program called " Blue manager suite " it manages you bluetooth devices ,came with drivers for one of the dongles , yet no joy
whats confusing it works fine for ez-b and PS3 Controller
re ps3 controller works like a dream with EZ-B ,takes a little setting up initially .
download motionjoy ver7 as that has a local feature ( not in the latest ver ) this is necessary if you want to use when you may not have Internet connection. confused
