Screen To Camera icon Screen To Camera — Capture any screen area and stream video to a configured camera device; requires a Custom device and 100% display scaling. Try it →
Arduino Infrared Module Kit As Table Top Edge Sensor?
in the video below i think the guy is using the arduino infrared module kit (link to ebay item below too)
i wanted to see if anyone here know if we can use this kit as edge detection. so my wall-e doesn't fall of the table.
in the video it shows that if even one sensor (either the transmitter or receiver ) go off the table the bot stops and reverses....
Can i assume the 2 sensors are always communicating the same voltage/value? and once that value changes (table is no longer there) the scrip command is to back up?
thanks in advance
ebay link to transmitter and receiver sensors
Netherlands
Twitter YouTube
This is not what you're looking for, those are 38Khz IR receivers for TV remotes etc.
I think this is more what you're looking for, they even output a analog signal based on the IR reflectance!
thanks for the heads up........how about this link
this is a transmitter and led......so this is essentially both pieces melted into one?
anywho this is what i found is this comperable to the one you pointed out?
linky!
Netherlands
Twitter YouTube
Yes, that one looks fine, but there you have to adjust sensitivity on the board itself, not via software, looks like it also just outputs a ADC value.
actually this one is a 3 pin connector, im trying to avoid having to solder.....
check this one out.
new sensor on ebay
to be able to adjust sensitivity on software, would the sensor have to be a digital vs analog?
thanks again for your help...
Mr. Netherlands
Netherlands
Twitter YouTube
For software sensitivity you could also choose digital, but it would be much harder than analog because you'll have to measure time for a capacitor to discharge so i would go with the one i just sent to you, can't be that hard, 3 wires?
yeah maybe your right, im going to have to solder when i get the mp3 trigger and the wifi cam....
thanks man
