Hi
I want in my plugin to get the Media Save Folder Path which is a parameter of Camera Control and to the twitter account name configured in ARC
Do you have ideas ?
Thanks
Sabertooth Kangaroo
— Movement panel enabling Kangaroo & Sabertooth encoder-based speed/velocity control, UART/PC serial options, tuning and encoder setup.
Hi
Do you have ideas ?
Thanks
@JLucben,
My initial advise is to create a custom application and the user tokens, although i knew it was possible to obtain and reuse the EZ-Robot tokens.
I didn't do it before DJ's approval.
So the code below is the short and effective answer:
although Twitterizer's API allows read direct messages, ez-robot application is not authorized to read the direct messages.
happy code!
My draft plugin is using user token with framemork tweetinvi , its working fine but it will be better just as cleaner integration to reuse the EZ-Robot tokens but they don't allow to day to access direct messages.
One limitation of tweetinvi to day is that you cannot send direct messages with file attachments. Do you know other one with this feature
Jean-Luc
@Jlucben,
coretweet: https://coretweet.github.io/
wiki: https://github.com/CoreTweet/CoreTweet/wiki/Using-REST-APIs
check the last example.
