Indoor Positioning System icon Indoor Positioning System — Infrared indoor positioning for ARC robots: dual-camera tracks IR beacon, shows real-time heading, path and EZ-Script navigation variables Try it →
About The Greedy Hand Control Comming Out Soon
Will it work for robosapien v2 model or do you have a script to open and close hand i see you are using IR s ensor to detect object in hand instead of pressure type sensors
It's in the store. Add a distance sensor to the hand like the video.:)
NO i meen the ezb script or module and will it work for robosapien v2 hand
The project can be found under the Examples in ARC.:)
Thanks DJ will give it a try on hand i have,i guess i need to modify the one on the ROBOSAPIEN V2 since i dont see any commands for hand open and close
Also found a lot of info on robosapien models ,full data,pins motors ,sensors ,chip and a lot more
WOWWEE hacks ,and info
Also order a great book on robosapien hacks callled " the official robosapien hacker's guide " i heard it was really great book,getting it in 2 days
DJ looks also good for my lynxmotion johnny project hand too,looking at changing the IR sensor to be a little smaller,like the ones used on NEATO XV-11 witch i have over 30 of and has a analog output and very close to same one you are using too
