Hi I have a simple question please
when making ARC mobile app; can i connect the app with Firebase Realtime Database to read and store variables? i want to use those variables to start and stop scripts...
thank you
Neopixel Ring
— ARC UI for onboard computers to control NeoPixel rings via serial: test/run patterns, preview and copy Arduino serial commands, includes sample code.
thank you
Someone else will have to answer. I have not done a lot of string functions in ARC, I just recognize what the issue is. Basically, you will need to use functions that extract just the answer of your query from the returned web page.
No, I am saying that your web front end to the database needs to return a simple easily parsed page when you send your query via httpget. If you are getting a lot of extraneous data, it is probably mostly stuff for displaying the return in nice human readable format, with colors and boxes and stuff (if you have a publicly accessible example, I can take a look and be more specific). What you want it an easily machine readable return because no human will be looking at it directly.I won't quote your third answer. Good enough reason.
hello, by "mobile interface" do you mean the one we find in ARC: Project >> add control >> mobile ? do you know if i can create my own mobile interface plugin? so i can provide it with database connections and display videos on the mobile screen? i'm currently working on making a firebase plugin; so if there is a way i can create a mobile interface out of this plugin, it would be really great and helpful! blush
No, I meant the Http server or Http server (custom) . You can design a web page hosted by ARC on the PC and accessed by your mobile browser. By doing this, you have the best of both worlds. The full power of the PC running the app, scripts, and plugins, and a mobile interface to access it.
The object you mention creates a mobile project for ARC Mobile (either iOS or Android) but it is somewhat limited, like no plugins.
