Python Native icon Python Native — Run real CPython in ARC with full package support, camera access, ARC APIs, and bidirectional robot control. Try it →
France
Encoding Character Question
Hi
I am trying to use TCP script interface client Tutorial 52
I have problem with french accent à é for example. The character is not received correctly in the TCP server and so not passed correctly to my plugin.
I have tried to change encoding in the send command code
tcpClient.Client.Send(System.Text.Encoding.ASCII.GetBytes(cmd + Environment.NewLine)); changed to tcpClient.Client.Send(System.Text.Encoding.GetEncoding("ISO-8859-1").GetBytes(cmd + Environment.NewLine));
I try also UNICODE and UTF8 encoding.
Is there a solution ?
All is working fine if I use EZ HTTP server to send the command.
Thanks for your help
The tcp server accepts ascii 8 bit single character byte characters, that means no encoding. Encoding requires multiple bytes per character. Your option will be to create a plugin with encoded character support.
