Frequency Detector icon Frequency Detector — Detect audio frequencies via PC microphone (FFT), output a variable and drive servos within configurable min/max ranges with waveform feedback. Try it →
Netherlands
Twitter YouTube
Hi DJ,
In your i2c help, you mentioned that the address is 7 bits correct me if i'm wrong but if you've got bit 0-7 then isn't it 8 bits?
Let me explain:
bit 0 - 1 bit bit 1 - 1 bit bit 2 - 1 bit bit 3 - 1 bit bit 4 - 1 bit bit 5 - 1 bit bit 6 - 1 bit bit 7 - 1 bit
You see? in total, you've got 8 bits now.
Edit: wait i'm confused blush please delete this thread.....
Netherlands
Twitter YouTube
@Bookmaker Yes, serial LCDs are so much easier, i have a sparkfun one that i got up and running in less than 10mins.
Anyways, Good luck with the library you found! If you need any help, hit me up.
Lyron, I don't know anything about i2c much less the library. May be DJ can give us a hand here?
@Bookmaker LINK:I2C SCL : Clock SDA : Data
clock is used to notify which device is going to be master in order to ship data across the I2C bus also to notify data: 1's and 0's.
