Personality Generator icon Personality Generator — Background randomizer that executes timed scripts to add lifelike actions (movement, servos, camera/control) and unique personality to your robot Try it →
Adc Ports
I just want to confirm, so as to NOT release the magic smoke, I want to trigger scripts wit the press of a button or the closing of a normally open contact. I figure that I connect the Red (3.3 Volts) and White (signal) on an ADC port across the switching contacts and have a script watching the assigned ADC port for change. I also planned to connect a pull down resistor across the signal to ground to keep floating voltages in check.
Is the above correct?
Also I may need a little help with scripting, How do I wright a script to watch and wait until the contact is closed, or opened again for that matter? I need the script to pause the personality generator at least and then I can build on it from there.
Thanks for any help in advance
Steve
Thank God!
That "." instead of a "," made all the difference. This problem has been kicking my butt for nearly a day
Thanks again guys
Steve
#18
Glad you got through this problem Steve. These little things are flusterating. When a script doesn't work for me the way I think it should the first thing I look at is the sentence structure.
It's all good Alan. I was the one who was confused. You knew exactly what you wanted to say. ;)
