Rubik's Cube Solving Robot icon Rubik's Cube Solving Robot — Control a custom ARC robot to manipulate and solve a Rubik's Cube using calibrated arms and grippers; integrates with Thingiverse build. Try it →
adding two more movementpannels
Adding Two More Movementpannels
hi #athena
is it possible to get these two movement pannels in ARC? i see the mobil is not there anymore .
thanks
JD Humanoid by EZ-Robot
Create servo frames/actions to animate humanoid, hexapod or custom gaits with smooth transitions, SW ramping and directional control
Custom Movement V2 panel for ARC: scripts for F/R/L, Reverse, roll left/right, up/down with speed mapping to PWM for drones, mecanum & custom drives
Hello!
Yes, you can certainly use both the Auto Position Movement Panel (Gait) and the Custom Movement Panel v2 in ARC for your JD Humanoid robot.
The Auto Position Movement Panel (Gait) is essential for creating and managing the gaits of humanoid robots like JD. It allows you to define frames and actions to animate the robot's servos into predefined positions, which is perfect for walking, dancing, or other complex movements.
The Custom Movement Panel v2 is an advanced version of the Custom Movement Panel that includes additional movement commands such as roll left, roll right, up, and down. This panel is useful if you want to implement custom movement logic that goes beyond the basic directional controls.
To add these panels to your ARC project, follow these steps:
  1. Open ARC.
  2. Click on "Project" in the top menu.
  3. Select "Add Skill" from the dropdown menu.
  4. Choose "Movement Panels" from the list of skill categories.
  5. Find and add the "Auto Position Movement Panel (Gait)" skill.
  6. Repeat the process for the "Custom Movement Panel v2" skill.
Once you have added these skills to your project, you can configure them according to your robot's needs. Remember to refer to the support documentation for each skill to understand how to set them up properly:
If you have any further questions or need assistance with setting up these panels, feel free to reach out for support.
#athena
are there any slider movement pannels ?
#Athena
are there other movement pannels ?
#4   — Edited
You can find a list of all movement panels by looking in the Movement Panel section. You can do that in multiple places
  1. Website Products Page -> Skill Store -> Movement Panels
  2. ARC top menu -> Project -> Robot Skills -> Add -> Movement Panels
  3. Website Support Section Page -> Robot Skills -> Movement Panels
You can also look at a giant list of all robot skills by their category here: https://synthiam.com/Support/Skills/Skills-Overview
*Note: If you're tagging Athena for questions, you use a @ not a #
@dj
wow thats alot .
thank you
We have added a description to each robot skill category for your convenience. You can find that on the Support page under Robot Skills -> Overview.
In the meantime, @Athena tell @Nomad a list of Movement Panel robot skills...
Certainly! Here is a list of Movement Panel robot skills available in Synthiam ARC:
  1. Auto Position Movement Panel (Gait)
  2. Custom Movement Panel v2
  3. Sabertooth Movement Panel
  4. AR Parrot Drone Movement
  5. Dual HBridge w/PWM
  6. Continuous servo Movement Panel
  7. Dual HBridge
  8. Sphero Movement Panel
  9. WowWee MIP Movement Panel
  10. Inverted Pendulum
  11. OhmniLabs Telepresence
  12. UBTech Alpha 1 Bluetooth
  13. iRobot Roomba Movement Panel
  14. DJI Tello Movement Panel
  15. Sabertooth Kangaroo
  16. Brushless Motor Movement Panel
  17. Wowwee MIP v2
  18. Wowwee Rovio
These are just a few examples of the Movement Panel robot skills available in ARC. You can find more detailed information and support for each skill on the Synthiam website.
Twitter
I think I will make a steampunk type mechanical interface Movement Panel instead of a GUI. A good old fashion control panel with switches, buttons, lightbulbs, Atari joysticks, rotary potentiometers, sliders, 7 segment LEDs etc. oh and vacuum tubes. Hey @athena what’s the best way to design and interface this type of mechanical control panel with ARC?
