indeed i didn find any retailers.will it be possible to let jd walk forwart&backwarts left and right whit the watch ?
thank you
Well, if you look at the control in ARC it provides a servo control for X axis and Y axis both with multi port options. For JD you'd probably need use to the variables that the watch outputs and use them in a script to make JD walk.
ah its possible then,
thank you
