Nuance Speech Recog
can i use speech recognition from nuance for ARC.will that work? on win7.i dont want to use my pc whit my voice just will ARC recognize, the speech engine.
thanks anyone
There are no plans to add nuance support for backward missing features of old operating systems. I would recommend upgrading to Windows 8, or 8.1.
Also, remember that windows 7 is nearly 10 years old and with Windows 10 coming around the corner, it should be available soon:)
win10 has speech recog?
Yes - Microsoft will not remove accessibility features of new operating systems.
I am hoping Microsoft does a good API for Cortana in Windows 10. They really hosed up SAPI in Windows 8.x. (as evidenced by all our issues getting other region voices to work in ARC).
I would love Nuance support too. They are the undisputed leaders in voice recognition, but their developer license is outrageously expensive.
win8.1 home has speech recog too?
@Nomad you already know it does... You have windows 8 on one of your PC, don't you?... Besides, how do you think everybody here (me, DJ and many others) have been using voice rec? I have been using voice rec for two years now...
rr no i didn know.is that not only for engLIch?
So all those videos of DJ made of JD, you didn't notice he was using voice rec to control JD? Have you seen my inMoov video? I am using voice rec to talk to my inMoov (well, Sue is actually)....
Voice rec is for multi languages now
nomad, it should work for your language - when you load the speech recognition control, what options are in the drop-down for languages in the config menu?
i have a look moment on win8
DJ beat me to it... You need any PC with Win7 professional/Ultimate or Win8/8.1 or Windows 10... and of course a microphone if your PC doesn't have one...
i set language to englich=canada but no luck
What language is your computer set for? You may need to install the language.
ok i found it.am downloading englich language on win8 now
than you guys
dj
What language would you prefer? Maybe your language is supported? Belganese
dj no only en-US the language is set also the mic. can you give me little excample what it can do.?
@nomad see where it says "Robot move Forward".... When you speak that your robor will execute the command Forward() (in the right side script)...So in the left side of the column you type in the command you want your robot to do... For instance.... "JD stand up" in the column beside it (right side) you type in a script or you can use ControlCommand to make your JD pose or do whatever... In this case you can have JD Pose by standing up straight.....
You can put as many voice commands as you want... The command that you will speak is on the left side... On the right side the script you want to run when you say that command....
rr
it doesn work.do i need speech recog for that?
#23
In the above picture you posted it shows you do have it... en-US .... You will need to use English... Does your Win8 PC have a microphone built in? Go to your control panel on your PC and look for "Speech Recognition".... If it's there then you have it...
ok i have to set the pc in englich language.i saw setting for speech recog. i use headset
#25
@Nomad... Windows 8 has speech recognition... I use it all the time... You have it on your Windows 8 PC too.... See here... read it all and watch the video at the bottom of the page.... Speech recognition The video is old, but it still applies....
i saw the video for now i cant find how to set pc in englich.
