Reboot your computer, router and ezb and try again.... Is there a blue flashing led on the ezb?
After you reboot, follow the tutorials on how to connect the ezb to your pc/network again.....
Your wifi is mac filtering to prevent your neighbors from hijacking as easy as they were before.
You will need to add the mac address to the permit list in your router to use client mode.
hi bolt.
d.cohran i forgot that.i have a look.
D.COHRAN
i found login page engius.but i dont see the page whit my devices.
I'm at the Dr right now and have a ton going on today. If you don't remember the password from that, I will have to send it to you tonight.
cohran
is it get your own wifi or wireless and then admin?
ah ok thank you
@nomad... Jeez, you got to write these things down so you don't forget....
RR
i do take notes ,but i forget where i put it.
login?
It goes red because it is locking up - this is most likely due to missing an i2c device. If you are connecting to the EZ-B with the JD project open, and there is no RGB LED connected, it will lock up the EZ-B because there is no communication with the RGB LED device.
Connect to EZ-B with a new blank project and not the JD project - you will be okay.
dj
i use a new project.i have to ad the ezbv4 on the ENginius page.
dj
dont understand why my password is not accseseble. i gess i am not regitered.whits i did now.hopes it works.
thanks all for the help.
cohran
i try bolt none works.i saw message its blokked i spook to the people from engenius but they are more stupid then , a dog whithout head. only them can block me. what can i do?
Can't you reset the EnGenius back to factory settings and start all over again?...
This time write down your login and password and put it on the fridge....:D
rr
there are no settings,only after you login. for some reason its blocked
iff you mean resetting the Engenius.am not touching that.
#19
Google it, there must be a way to reset it... Perhaps you should wait for David to help you with this again.....
#20
I am not able to connect at this time. I can get in touch with you tonight. I have more pressing matters that I am attending to at this time.
You can reset to factory settings by holding down the button on the top of the engenius for 10 seconds but, you will then have to setup your network again.
rr
i ask them to send reset mail,they anwser no need for register. i always use google. i didn make an error.they blocked me.i never bin on that page.
cohran
how do i get on that page?
#23
@Nomad... I have no idea what your are talking about but did you reset the EnGenius by pressing the button like David said? Perhaps you should wait until David can talk you through this...
rr
yes my avening is ruin anyway yes i did 10 sec as he said. anyway i have to blow off steam.
thanks
#25
@Nomad you have to stop doing these kind of things.... Eventually no one will want to help you... You have to learn this stuff yourself and be very careful when you do things... We have a saying in English... measure twice and cut once... It means always check again before doing something so you minimize the chance of making a mistake...
If you're letting off steam... don't throw JD, he won't be happy after that...:P
rr
these things i dont learn.i cant explain why but it is so. i would understand iff no ones is able to help me,no matter the reason. one thing for sure there are to many changes for me to handle. so its the web page from ENgenius for sure. maybe i need to go back to lego.
thanks avery one
#27
ahhh who am I kidding... we'll always help you....:)
#28
The site to posted is for engenius website. That's not your router.
I can remember your routers ip address off the top of my head, but it will be 192.168.1.something.
To configure your router, you will need to connect to your routers Web page so it would be something like http://192.168.1.254
I am with my wife who is very sick right now. I can't help you immediately and if you have reset your router, you have taken this from a 5 minute fix to a hour or more fix. Your situation is aggravated by having some smart but difficult neighbors who love to hack your wifi signal.
I will try my best to get in touch with you tonight. My time is very limited with a sick wife and daughter who is having some issues, my normal job, my side job in which I am in the middle of recovering 12 TB of data and me just trying to keep my head above water. If I can't contact you tonight, I will at my earliest possible time. This not being a weekend makes it more difficult.
cohran
dont worry .i got plenty off time. take care miss cohran.
d.cohran
thank you again for learning me these settings.
#32
@Nomad... Now go write down your user name and password and put it on your fridge or your forehead....:P
