How did you manage that? Find internet explorer on your PC and drag and drop it to your taskbar (pin to your taskbar)... done...
For that matter, you can drag and drop any program to your taskbar... I have ARC on mine....;)
i can see in sttings its connected,but i dont see the icon in there,only one icon off dissconnect. good idea to put ez in there.
ok ez is in there. i saw somewhere i can coose an icon,but cant find it back.
Ok, you mean the wifi icon... I do see it in your taskbar group icon window in the second image you posted (in the bottom right hand corner of the image)...Did you reboot your computer yet?
not rebooted.in the group icons is the one that says your not connected.
You obviously have internet because your here... Reboot your PC, Router and modem (if you have one)....
yes sometimes it chows the red circle in second pic.. where can i find the page where i can choose an icon for the internet?
So you don't like the regular Internet Icon and want to change it?
yes i wanted to see if i bin connected to the internet.cause the internet falls out sometimes.
maybe this pic is better.here can you see,all icons for taskbar whits are in there, except the icon wifi.
I am not exactly sure what you want to do...Is you computer wifi or are you connected to the router with network cable?
wifi to router.normal it chows icon from wifi connected in the taskbar below right.no cable
I am still not sure what you need... Maybe someone else can chime in and help... sorry dude...
maybe this pic helps.
Do you see the button with the arrow up in the taskbar (lower right beside the little flag)?... This is where more taskbar icons are... It should be in there, click on the icon with the arrow... If it is, see if you can drag the wifi icon to the taskbar....
Right click your taskbar and select properties... In there under the Taskbar tab you can choose which icons to show (where it says taskbar buttons)... I think you need to choose, "never combine"... But try different settings a see what happens in the taskbar...
You can't change the wifi icon, it changes by itself depending on the status of the adaptor.
You have the wifi icon it's just set to hide itself. Change it to show all the time by clicking customise when you click the arrow to bring up the group of tasktray icons.
Fix whatever the error is and the red/yellow star will be removed from the icon and it should show the icon you are trying to get.
What is the error that is reported when you hover the icon?
no errors has bin given.i can chow it up for all the time to see.but its the wrong icon.
It's the wrong icon because it has errors. The symbol it's showing is indicating a problem.
Without us knowing what that problem is we are unable to help you.
Clearing the problem will restore the icon you are trying to get. Try right clicking on it and going through the troubleshooting.
i did try that no errors.its a misterie.
Reboot the router (i.e. disconnect it from the mains for around a minute then connect it again)
Update the driver for the WiFi NIC along with any other driver updates available for the PC.
The icon is indicating a software issue, most likely the configuration of the router or of the NIC itself.
i think your wright. earlier first wifi was d-link whit some reciever.when they installed on my new adres,they didn use the reciever.dont know why.mybe i need to call them back.
OK it's saying that a network cable isn't connected... what network adapters are installed?
Post a screenshot of
Control Panel\Network and Internet\Network Connections
It may just be a case of disabling a network adapter that's not in use but is reporting an error because it's not plugged in.
Disable all network adapters which aren't being used, more specifically the two with the red crosses on them (not the bluetooth one though).
You should remove all adaptors really since it looks like there may be a few which aren't really there but for now just disable them and see if that solves it.
rich you have an amazing brain.problem solved. it was the first adapter from an old robot i had online.
thank you all .
ive seen this only twice in the 5 years i do robotics. just helping whit personal problems whit pc's so far. it chows great character rich is. thank you
It's no problem:)
And I know Dave is joking there but I really don't do it for the $3 a pop, I'd still do it if it was only $2.50;) Seriously though, helping others is a reward in itself.
Glad the problem is sorted.
haha 2.50$
you thinking my way.am just desame person.only diff things.
