i did an update and get error.anyone plzze.
Community Robot Questions Error In Update PRO Nomad 6R Belgium Asked Feb 2014 — Edited Feb 2014 Error In Update Skip to comments Jump To End i did an update and get error.anyone plzze. Upgrade to ARC Pro Experience early access to the latest features and updates. You'll have everything that is needed to unleash your robot's potential. Compare Pro Features View Subscription Plans Rich United Kingdom #1 Feb 2014 Looks like it can't find the cloud, which isn't surprising since if you look at the wifi you aren't connected properly. It indicates the problem is with your wifi not ARC. Nomad 6R PRO Belgium #2 Feb 2014 ah ok i check thanks Nomad 6R PRO Belgium #3 Feb 2014 the wifi works. i can go on the internet. you have idea where to look? blush CardboardHacker Canada #4 Feb 2014 If your connected to the internet it should work now... Nomad 6R PRO Belgium #5 Feb 2014 no still desame Rich United Kingdom #6 Feb 2014 In the image you posted you have an error with your wifi connection indicated by the orange star, Windows should tell you what the problem is if you check your network settings. DJ Sures PRO Synthiam #7 Feb 2014 you will require a connection to the internet to use the cloud service. Nomad 6R PRO Belgium #8 Feb 2014 i gess its ok now.i install it as admin. Login to post a comment
no still desame
