Elseif Is Broken
@DJ,
The ElseIf is broken:
The code below never stops !
$buffer="[123 456 789]"
$len=Length($buffer)
$ix=0
$start=-1
$end=-1
repeatwhile($ix<$len)
  $ch=GetCharAt($buffer, $ix)
  if ($ch="[")
    print("found start")
    $start=$ix
  elseif ($start>=0 AND $ch="]")
    print("found end")
    $end=$ix
    # break
    $ix=$len+1
  endif
  print("increment ix")
  $ix=$ix+1
endrepeatwhile
print($ix)
print($start)
print($end)
if you remove the ElseIf it works as expected.
$ix=0
$start=-1
$end=-1
  if ($ch="[")
    $start=$ix
  endif
    print("found end")
    $end=$ix
    # break
    $ix=$len+1
  endif
  $ix=$ix+1
endrepeatwhile
print($ix)
print($start)
print($end)
This bug must be recent, i've used before the ElseIf, or did i miss something ?
Does the ElseIf require its own EndIf?
This is one thing I've never been clear ablout EZ Script as other languages do require that but EZ Script doesn't seem to require it
@faengelm:
No. Only one Endif for the If clause.
Tutorial: https://synthiam.com/Community/Tutorials/134/1
Some languages have optional code blocks and don't need the endif: C, C#, Java { } TSQL: Begin ... End
Python uses indentation and sometimes is a pin a neck (tab vs spaces):
if expression1:
   statement(s)
elif expression2:
   statement(s)
elif expression3:
   statement(s)
else:
   statement(s)
Curiosity, what program language do you have in mind that requires 2 endifs ?
@ptp You are right. I was confused by the case where instead of an ElseIf there is an Else with a nested If ... Endif
Hi @PTP I tried the simplest
If ElseIF EndIf
I could think of and this is working both trying $a=1 and $a=2
$a=2
:loop
if ($a=1)
  Print( "$a= " + $a)
elseif ($a=2)
  Print( "$a= " + $a)
endif
Sleep( 2000 )
Goto(loop)
I'm using ARC 2017.05.14
Maybe the ElseIf issue has been fixed
Regards, Frank
Frank:
Did you tried my code and is working for you ? I just tried my code with the new version and the bug is still present.
Simple example 2 (broken):
$a=11
print("Start")
if ($a=1)
  print("one")
elseif ($a=3)
  print("three")
elseif ($a=5)
  print("five")
endif
print("End")
output: script does not stop and keeps printing "Start".
Simple example 3 s[/s] WORKING:
$a=11
print("***Start")
if ($a=1)
  print("one")
ELSEif ($a=3)
  print("three")
ELSEif ($a=5)
  print("five")
ELSE
  print("another number")
endif
print("End")
output: Start ***Start another number End
#EDIT: This example works, Start is not duplicated, i confused the second start with ARC Start
Frank:
didn't took me long to break your code:)
$a=3
:loop
print("before")
if ($a=1)
  Print( "$a= " + $a)
ELSEif ($a=2)
  Print( "$a= " + $a)
endif
print("after")
Sleep( 2000 )
Goto(loop)
The code above is broken
I can confirm what @ptp is saying... None of his examples seem to work...
@Richard R: Last version ?
@ptp You are right! I forgot to check the boundary conditions..
$A=3 breaks it with the latest ARC
I get the same "Start" message that you do
Thanks, Frank
$a=11
print("Start")
if ($a=1)
  print("one")
ELSEif ($a=3)
  print("three")
ELSEif ($a=5)
  print("five")
ELSE
endif
print("End")
Outputs (correct):
Quote:
Start Start another number End Done (00:00:00.0156256)
$a=3
print("Start")
if ($a=1)
  print("one")
ELSEif ($a=3)
  print("three")
ELSEif ($a=5)
  print("five")
ELSE
endif
print("End")
Outputs (correct):
Quote:
Start Start three End Done (00:00:00.0155859)
$a=5
print("Start")
if ($a=1)
  print("one")
ELSEif ($a=3)
  print("three")
ELSEif ($a=5)
  print("five")
ELSE
endif
print("End")
Outputs (correct):
Quote:
Start Start five End Done (00:00:00)
@DJ,
It's fixed in your version ? Current version does not work.
I'm using the same version as you.
Your examples are all incorrect - surprised none of you caught any of the incorrectness:D
If you copy and paste my code into your copy of ARC, you will receive the same output. Copy and paste, do not type it because there's lots of mistakes being made in this thread example code. Such as the $a=11 lol
@DJ:
What is the mistake in the code below ?
$a=11
print("***Start")
if ($a=1)
  print("one")
elseif ($a=3)
  print("three")
elseif ($a=5)
  print("five")
endif
print("***End")
the code above produces this:
Let me take a look and see how this can be... stay tuned
#18
An IF or ELSEIF needs an ELSE to finish the clause before the ENDIF.
You can make the ELSE do nothing, but it is still required (at least in EZ-Script. Might be implied in some languages).
Not sure this has always been the case, but it is the difference between the failing and the succeeding cases.
@ptp
Yeah, I edited my post to say I am not sure this has always been the case, but is the difference between the working and failing code. Was to point DJ towards cause of bug, not to say scripts were wrong.
yes i agree with you.
it seems the problem is when the condition is false and no else is found.
OK:
print("***Start")
$a=1
repeatwhile($a<=9)
  if ($a=1)
    Print("1")
  ELSEif ($a=2)
    Print("2")
  ELSEif ($a=3)
    Print("3")
  ELSEif ($a<10)
    Print("less than 10 a="+$a)
  endif
  $a=$a+1
ENDrepeatwhile
print("***End")
if you change the condition:
repeatwhile($a<=10)
it get lost forever:
Fixed for next release (later tonight)...
$start=-1
$end=-1
repeat ($ix, 0, length($buffer) - 1, 1)
  if ($ch = "[")
    $start=$ix
  ELSEif ($ch = "]")
    print("found end")
    $end=$ix
  endif
ENDrepeat
print($start)
print($end)
Outputs:
Quote:
Start found start found end 0 12 Done (00:00:00.0337752)
