hi did anyone used some tires on roli? insteadt off rups.
Community Robot Questions Does Tires On Roli Exist ? PRO Nomad 6R Belgium Asked Jan 2018 — Edited Jan 2018 Does Tires On Roli Exist ? Skip to comments Jump To End hi did anyone used some tires on roli? insteadt off rups. Upgrade to ARC Pro ARC Pro is your passport to a world of endless possibilities in robot programming, waiting for you to explore. Compare Pro Features View Subscription Plans Dunning-Kruger Canada #1 Jan 2018 Roli is only 2 wheeled drive so unless you use omni type wheels (or two more motors) 4 regular rubber tires won't work... Roli was designed to use tank treads... Nomad 6R PRO Belgium #2 Jan 2018 ah thanks RR two motors more means also Hbridge more. are there better motors to get,these makes a lot of sound,little speed. Dunning-Kruger Canada #3 Jan 2018 No, you don't need another H-bridge... You just parallel the wires for 2 motors on one side and 2 motors on the other side... Just one H-bridge Nomad 6R PRO Belgium #4 Jan 2018 you mean just the pos+ and the negati - conected from the motors on the hbridge. so i have then 4 wires each side. will that give more speed and sound ? thanks for helping Dunning-Kruger Canada #5 Jan 2018 Yes Nomad 6R PRO Belgium #6 Jan 2018 are there any motors to get that are much quiter ? and are the original motors with plastik gears or metal ones. has any one a good link. Login to post a comment
thanks for helping
Yes
