Prevent PC Sleep icon Prevent PC Sleep — Prevents a PC from entering sleep mode via a tiny, resizable control-keeps the system awake while minimizing UI real estate Try it →
Adding Phrases, How Many?
So I got a weird issue, maybe. Its related to the Speech Recongnition tool, for EZB and I could not find an answer to this.  I have been adding phrases to the list, each one of course performs a simple servo movement or performs a script. When I click on the gear icon, it of course displays the phrases including the preinstalled ones. I counted I have 17 phrases  that show up with in that window, and if you use the slider, I have 2 more phrases, for a total on 19.  The issue is that the first 17 phrases preform fine, but for the last two, when spoke, EZB says "Weird, heard but not detected:"  Is this because I have exceeded the limit of phases allowed to be entered? or because if they dont show up initally on the list  that they will not execute? Silly question maybe, but I know that these two additional phrases do infact work, if I  use a smaller list of command in the Speech Rec  app. I am puzzled, any ideas?? Thank you:)
Windows Speech Recognition skill: detect custom phrases via PC mic, trigger configurable scripts/actions with adjustable confidence.
What version of ARC are you using
Im still using that last Version of ARC ( the one before ARC)- 2020.01.05.00
Upgrade to arc. That’s a known bug with ARC. Upgrades fix bugs
ahhh, ok. good to know. thanks:)
