hi does any one has the size from jd head .1 ear to ear 2 ear to nose 3 eye socket.
Community Robot Questions Sizes Jd Head PRO Nomad 6R Belgium Asked Feb 2014 — Edited Feb 2014 Sizes Jd Head Skip to comments Jump To End hi does any one has the size from jd head .1 ear to ear 2 ear to nose 3 eye socket. Upgrade to ARC Pro Become a Synthiam ARC Pro subscriber to unleash the power of easy and powerful robot programming Compare Pro Features View Subscription Plans Sudo the Banned USA #1 Feb 2014 Might this be for the glasses you plan to put on him? Nomad 6R PRO Belgium #2 Feb 2014 yes he gets two pair if i can get them.one normal transparent and one sun glases. also the neckservo if i can get them.its 7.4 volts.from robi. Rich United Kingdom #3 Feb 2014 JD Head Shop Page gives the dimensions. 8cm x 8cm x 11cm Open up the SLT from ARC in your favourite 3d software, scale the head to match the dimensions from the shop (if required) and measure the specifics to your hearts content Nomad 6R PRO Belgium #4 Feb 2014 thank you blush does any know the eyesocket dia? Nomad 6R PRO Belgium #5 Feb 2014 i see two sound boards one is from the ez-b4 from whits one will be my voice? blush Rich United Kingdom #6 Feb 2014 Every control has a ? which will take you to the help page. The Soundboard v4 is the EZ-B V4s sound board. Use the Microphone control for voice passthrough. Nomad 6R PRO Belgium #7 Feb 2014 ez-b4 is my voice then.thanks. Login to post a comment
thank you blush
