Yep, looks normal. It does mention it in the listing too...
there is no manuel in the box.how do i now if its connecting
Can you test it in ARC? Also it should show up in device manager...
i dont see it in device manager.but i can see it in my usb devices printers.i check if i can see it in ez.
found it in manager .but dont see it in ez
If it's detected in devices then it should show up in ARC. Try refreshing the joysticks or restarting ARC.
his page says win7.but on the box not?
Netherlands
That's the same joystick as I have. Are you sure it's not the one you've selected in ARC? Try moving the analog sticks and pushing the buttons and see if the blue dot moves too.
Netherlands
I just talked to @nomad on Skype. His controller appears to have liquid that leaked to the front, which may be the cause of this defect.
can i get the liqiud out?found another problem.
Netherlands
The liquid might have already corroded the inside, so your best bet is to get a refund / new one.
I was afraid of this happening to my controller, so the first thing I did was remove the liquid containers.
heb al een mail gestuurt.de doos is beschadigd ook.
Seems like the liquid left their storage areas and got everywhere. Definitely try to get a refund or exchange. I see this kind of thing happen when the devices are exposed to freezing temps and next thing ya know the liquid is everywhere.
i think this box has fallen off somewhere.box is damage.
found it.it stops blinking and connect.
why are not all buttons availeble for use in ez ?
#17
If it works, I suggest cleaning it out ASAP to avoid any problems later on.
i allreddy clean it out.its a cheap one 13 euro.and i removed the liqiud containers too.:D
wel the seller will not send me a new one.but he still want 5 stars on his ebay chop.whall i do?
#20
Report him to eBay, they'll deal with it for you if leave a support ticket.
he gave me a refund 8 dollar.its so stupid all this trouble for a remote from 13 dollar. why are not all buttons availeble in ez for using.its eather right or left.
#22
The remote may be defective so the ARC is unable to see the mapping bits for all the buttons.
the remote works all buttons.just cant see all in ez
