rr yes i only use google
....and?... did you find the manufactures web page? That's where I would look first for a product's driver... Then do an internet search if I didn't find it there...
rr
you have to go to there site texas instruments and make an account. then you have to send a request to ASKTEXAS@TI.COM whit some personal info about yourself and what you gonna use it for.
dj
this is a microsoft cerfied driver for the chronos. what do i need to download 1 or all 3?
driver
@nomad... I only see the windows exe installer package in your link above.... What 3 drivers are you referring to?
RR
there chould be a driver there.dont know what the others are ,but consider the, error it gave i think its importent.
discription
The driver(s) are installed using the Windows exe file that is listed there .... Download the windows exe file... run it and it will install the drivers automatically....
rr
hopes it works
thanks
Just be aware, it could just be the same drivers you already have...
rr
then i removed and am done whit ez chronos.
dj
is this correct?
@nomad... don't go messing around with com port settings... There is no need to... Windows configures these ports automatically... If your watch doesn't work properly (as DJ mentioned) there could be a problem with the driver itself...
Maybe you need to wait for your Myo to arrive....
rr
sofar its working and norton says its good.but i know in a day orso. this week i expect all parts kd the myo end off this month. i never mess whit port setting,just wanted to know if these are ok. i power off the pc allreddy one time,sofar good.
thank you
nomad, those settings look correct
its desame driver,but before power off your pc you have to remove the dongle, (adaptor) then windows close normal.
